powermill 10 sp5 dawnload
Başlatan Rodop_boy, Mayıs 06, 2010, 01:42:54 ÖS
Rodop_boy
Delcam PowerMill 10 SP5 + Extras (2009-2010) | 2.51GB
[IMG]http://img714.imageshack.us/img714/9242/2iabmaf1.jpg[/img]
Uploaded with ImageShack.us
Description: Delcam PowerMILL - package for the preparation of high-control programs for CNC milling machines.
Features
* Delcam PowerMILL traditionally considered the best management training programs (UP) for milling of complex shapes
* Easy to use: very often installed directly on the shop floor
In particular we use:
* In the aircraft industry
* In the automotive
* In the shipbuilding
* When making:
- Molds and dies
- Turbine blades
- Medical devices
Features Delcam PowerMILL:
* Flexible strategies for roughing and finishing
* High speed calculation of control programs
* Powerful editing tool for managing programs
* Integrated tools to visualize and verify
* 100% guarantee against zarezany
* Import of solid, surface and faceted models, and frame geometry in various formats: AutoCAD, STL, STEP, IGES, VDA, DXF
* Additionally, you can use the direct system interfaces Delcam Exchange
* Undemanding quality data, and performs processing without zarezany even if there are gaps in the surface model
* The library of standard post processor plus configurable postprocessor
* Processing of 2,5 D without a three-dimensional model of a sketch or imported drawing
* Automatic detection of planar regions, recognition of holes
* Closure of the holes and grooves for preventing their processing
* A flexible mechanism to limit the boundaries of the zone processing
* Generate maps adjusting for control programs
* Maps of adjustment are in HTML format and can be adapted by the user
Advanced Features Pro Version:
* Use the workpiece of arbitrary shape
* Generate a model residual material
* Rough revision with reference to the trajectory or residual material
* The sample dive
* Use a disk cutter and cutter of arbitrary shape
* Fair projection methods for processing
* Automatic refinement of the angles
* Processing of 3D displacement with the option spiral trajectory
* Special features create trajectories for high-speed processing
* Trochoidal and "racing" treatment
* Control of collisions in the light of the holder and the mandrel
* Batch
User interface:
* Convenient and easy to use interface in the style of Windows, including the project tree
* Russification menus, documentation, help
* Setting for a particular user
* All parameters are set in one form (the choice of instrument, borders, transitions, smoothing, etc.)
Extras. Information: Here there are "associated" software products that may be necessary programmer technologist (Dental, DentMILL, ductpost, Exchange, FeatureCAM, PostProcessor, PowerMILL2Vericut, PowerSHAPE, PowerINSPECT). All versions - the workers.
In dop_material the folder located screensaver, desktop wallpapers, and a brief description of the new features PowerMill 10.
System requirements: PowerMILL 10 works on the same hardware as PowerMILL 9. The calculations in the background, running on uniprocessor computers, and dual-processor computers also provide significant performance benefits from the use of parallel processing.
For all the benefits PowerMILL 10 recommend:
* Intel ® Core ™ 2 Quad Q9550 (2.83GHz, 1333MHz FSB, 12MB L2 Cache, Quad Core) 375W
* 8GB (4 x 2.0GB DIMM) 800MHZ ECC Dual Channel Memory (requires 64-bit O / S)
* 512MB PCIe x16 nVidia Quadro FX 3700 (MRGA15), DualMonitor DVI or VGA Graphics Card
* 2 x 320GB (7,200 rpm) SATA 3.0Gb / s Hard Drive with NCQ and 16MB DataBurst Cache ™
* Genuine Windows Vista ® Business x64 SP1
If the central point for you is the computing time, the two quad-core processor will perform the calculations in the background and the active mode at maximum speed.
* 2 x Intel ® Xeon ® X5450 (3.00GHz, 1333MHz, 2x6MB Cache, Quad Core)
* 16GB, 667MHz, ECC Memory (8x2GB)
* 512MB PCIe x16 nVidia Quadro FX 3700 (MRGA15), Dual Monitor DVI or VGA Graphics Card
* Genuine Windows Vista ® Business x64 SP1 WITH Media
Some clarifications on the application of tablets:
1. Our beloved spawn heap Microsoft OS, so you may need to select the version of Flex, which you earn (file lmgrd.exe). The archive is version 11.6.1.0. Who will not work - is present in the distribution archive lmgrd.rar, containing 7.0, 9.2.2 and 11.4. Try one of them exactly you will earn.
2. Regarding the environment variable. The computer name that you enter must contain only letters, numbers, dashes and underscores. No Cyrillic, and so is not suitable. If you do not want to change the computer name, you can specify its IP. What is even more preferable. Ie name of environment variable may take the form: 1700@192.168.50.200, but not 1700 @ PK_krutogo_Vasi.
3. Keep in mind that security server (Flex) can be installed on your computer, different from the one which is set PowerMILL, etc. Ie one computer set Flex, but on the other - works / UT user / Do. In this case the environment variable should contain the name of the computer (or IP), on which you installed Flex.
4. If you can not install the Flex as a service can start the server protection via a batch file. Example batch file is present in the distribution. The batch file must be in the Flex server. General view of the following
Quote:
lmgrd-z-c dcam.lic
Where dcam.lic filename license. If there is a need to obtain the log of the server (and it is sometimes useful), then run the string will look
Quote:
lmgrd-z-c dcam.lic-lc: \ flex \ my_flex.log
. It should be noted that such a launch server via a batch file must occur before running programs like PowerMILL. It is better to install this batch file in the Startup folder.
5. Port TCP / IP, specified in the current license (1700), may be replaced by any free above 1024. For example, 55999. Naturally, the port should be free. The replacement of the port must be carried out simultaneously in the license file and environment variable. If you use a firewall port to be included in the exceptions, not to block the exchange between the server and client. The best option is when the network exchange and delcam.exe lmgrd.exe made to the firewall exceptions.
Info:
Year: 2009-2010
Version: PowerMILL Pro 10.006 SP5 CodeBase 1117241
Developer: Delcam
Platform: Windows (XP SP3 guaranteed and above)
Compatible with Vista and Seven: total (x32 and x64 OS)
Language: English + Russian
Download from Hotfile:
http://hotfile.com/dl/27626878/55a5712/Delcam.part01.rar.html
http://hotfile.com/dl/27626889/b010aa2/Delcam.part02.rar.html
http://hotfile.com/dl/27626891/fb9025c/Delcam.part03.rar.html
http://hotfile.com/dl/27626882/ae6e150/Delcam.part04.rar.html
http://hotfile.com/dl/27627233/8ec31b9/Delcam.part05.rar.html
http://hotfile.com/dl/27627244/8b2fd1c/Delcam.part06.rar.html
http://hotfile.com/dl/27627264/c4d1240/Delcam.part07.rar.html
http://hotfile.com/dl/27627313/01780d6/Delcam.part08.rar.html
http://hotfile.com/dl/27627570/ecda581/Delcam.part09.rar.html
http://hotfile.com/dl/27627606/cf663e0/Delcam.part10.rar.html
http://hotfile.com/dl/27627645/906204f/Delcam.part11.rar.html
http://hotfile.com/dl/27627671/90ce810/Delcam.part12.rar.html
http://hotfile.com/dl/27627908/7109140/Delcam.part13.rar.html
http://hotfile.com/dl/27627948/426c0d0/Delcam.part14.rar.html
http://hotfile.com/dl/27627960/68fafdc/Delcam.part15.rar.html
http://hotfile.com/dl/27627993/cba8330/Delcam.part16.rar.html
http://hotfile.com/dl/27628206/f44da46/Delcam.part17.rar.html
http://hotfile.com/dl/27628258/3e61029/Delcam.part18.rar.html
http://hotfile.com/dl/27628262/ffe31a0/Delcam.part19.rar.html
http://hotfile.com/dl/27628268/64000bf/Delcam.part20.rar.html
http://hotfile.com/dl/27628380/b26f6e4/Delcam.part21.rar.html
http://hotfile.com/dl/27628424/645b4ff/Delcam.part22.rar.html
http://hotfile.com/dl/27628440/392751d/Delcam.part23.rar.html
Download from Uploading:
http://uploading.com/files/7f18e5f5/Delcam.part04.rar
http://uploading.com/files/e264bcd3/Delcam.part03.rar
http://uploading.com/files/d2m3m255/Delcam.part02.rar
http://uploading.com/files/2e862ef4/Delcam.part01.rar
http://uploading.com/files/7145f4m8/Delcam.part06.rar
http://uploading.com/files/34e7a864/Delcam.part05.rar
http://uploading.com/files/7cdc8e54/Delcam.part07.rar
http://uploading.com/files/71482c77/Delcam.part08.rar
http://uploading.com/files/f76b45me/Delcam.part11.rar
http://uploading.com/files/3326e1a3/Delcam.part10.rar
http://uploading.com/files/3d6b45m3/Delcam.part09.rar
http://uploading.com/files/784m9edb/Delcam.part12.rar
http://uploading.com/files/1dd94e55/Delcam.part13.rar
http://uploading.com/files/b761a138/Delcam.part14.rar
http://uploading.com/files/577d6mec/Delcam.part15.rar
http://uploading.com/files/9327b227/Delcam.part16.rar
http://uploading.com/files/61fccad1/Delcam.part17.rar
http://uploading.com/files/76afmm83/Delcam.part19.rar
http://uploading.com/files/c5d1e5ce/Delcam.part18.rar
http://uploading.com/files/3ba5mmm7/Delcam.part20.rar
http://uploading.com/files/ff44cfmb/Delcam.part23.rar
http://uploading.com/files/eefd54d3/Delcam.part21.rar
http://uploading.com/files/28bm653f/Delcam.part22.rar
http://rs-catalog.com/software/graphics-and-design/35172-delcam-powermill-10-sp5-extras-2009-2010.html
Usta Adam Takımelbiseyle Çalışır, Üzerinine Bir Damla Yağ Sürmeden İşini Bitirir...
Rodop_boy
yasintoklu
#2
aaa
