sık kullanılan G kodlar
Başlatan GAKKO2323, Şubat 12, 2009, 10:41:48 ÖS
GAKKO2323
EN SIK KULLANILAN G KODLARI
ingilizce kodlar....
G00 positioning (rapid traverse) G54 work coordinate system 1 select
G01 linear interpolation (feed) G55 work coordinate system 2 select
G02 circular interpolation CW G56 work coordinate system 3 select
G03 circular interpolation CCW G57 work coordinate system 4 select
G04 dwell G58 work coordinate system 5 select
G07 imaginary axis designation G59 work coordinate system 6 select
G09 exact stop check G60 single direction positioning
G10 offset value setting G61 exact stop check mode
G17 XY plane selection G64 cutting mode
G18 ZX plane selection G65 custom macro simple call
G19 YZ plane selection G66 custom macro modal call
G20 input in inch G67 custom macro modal call cancel
G21 input in mm G68 coordinate system rotation ON
G22 stored stroke limit ON G69 coordinate system rotation OFF
G23 stored stroke limit OFF G73 peck drilling cycle
G27 reference point return check G74 counter tapping cycle
G28 return to reference point G76 fine boring
G29 return from reference point G80 canned cycle cancel
G30 return to 2nd, 3rd & 4th ref. point G81 drilling cycle, spot boring
G31 skip cutting G82 drilling cycle, counter boring
G33 thread cutting G83 peck drilling cycle
G40 cutter compensation cancel G84 tapping cycle
G41 cutter compensation left G85,G86 boring cycle
G42 cutter compensation right G87 back boring cycle
G43 tool length compensation + direction G88,G89 boring cycle
G44 tool length compensation - direction G90 absolute programming
G49 tool length compensation cancel G91 incremental programming
G45 tool offset increase G92 programming of absolute zero point
G46 tool offset decrease G94 per minute feed
G47 tool offset double increase G95 per revolution feed
G48 tool offset double decrease G96 constant surface speed control
G50 scaling OFF G97 constant surface speed control cancel
G51 scaling ON G98 return to initial point in canned cycle
G52 local coordinate system setting G99 return to R point in canned cycle
STANDARD "M" KODLARI
M00 program stop M21 tool magazine right
M01 optional stop M22 tool magazine left
M02 end of program (no rewind) M23 tool magazine up
M03 spindle CW M24 tool magazine down
M04 spindle CCW M25 tool clamp
M05 spindle stop M26 tool unclamp
M06 tool change M27 clutch neutral ON
M07 mist coolant ON M28 clutch neutral OFF
M08 flood coolant ON M30 end program (rewind stop)
M09 spindle orientation ON M98 call sub-program
M19 spindle orientation ON M99 end sub-program
GAKKO2323
G00 = Rapid hareket-kesmeden hızlı ilerleme
G01 = Lineer interpolasyon-keserek hızlı ilerleme
G02 = Dairesel interpolasyon /Helisel interplosyon saat yönü
G03 = Dairesel interpolasyon /Helisel interplosyon saat yönü tersi
G04 = Bekleme, tam durma
G05 = Yüksek hizda isleme çevrimi
G09 = Tam durma
G10 = Veri düzenleme
G11 = Veri düzenleme modu iptali
G15 = Polar koordinatlar iptali
G16 = Polar koordinat modu
G17 = XY düzlemi seçimi
G18 = ZX düzlemi seçimi
G19 = YZ düzlemi seçimi
G20 = Inç sistemi
G21 = Metrik sistem
G22 = Kurs kontrol fonksiyonu açik
G23 = Kurs kontrol fonksiyonu kapali
G27 = Referansa gitme kontrolu
G28 = Referans noktasina gitme
G29 = Referans noktasindan geri gelme
G30 = 2nci, 3ncü ve 4ncü referans noktalarina gitme
G31 = Atlama fonksiyonu
G33 = Dis frezeleme
G37 = Otomatik takim boyu ölçme
G39 = Dairesel interpolasyonda köse telafisi
G40 = Takim yariçap kompanzasyonu iptali
G41 = Takim yariçap kompanzasyonu sol
G42 = Takim yariçap kompanzasyonu sag
G43 = Takim boyu kompanzasyonu + dogrultu
G44 = Takim boyu kompanzasyonu - dogrultu
G45 = Takim telafisi artirma
G46 = Takim telafisi azaltma
G47 = Takim telafisi çift artirma
G48 = Takim telafisi çift azaltma
G49 = Takim boyu kompanzasyonu iptali
G50 = Ölçeklendirme iptali
G51 = Ölçeklendirme modu
G52 = Yerel koordinat sistemi verme
G53 = Makina koordinat sistemi seçimi
G54 = 1 nolu is parçasi koordinat sistemi seçimi
G55 = 2 nolu is parçasi koordinat sistemi seçimi
G56 = 3 nolu is parçasi koordinat sistemi seçimi
G57 = 4 nolu is parçasi koordinat sistemi seçimi
G58 = 5 nolu is parçasi koordinat sistemi seçimi
G59 = 6 nolu is parçasi koordinat sistemi seçimi
G60 = Tek yönlü pozisyonlandirma
G61 = Tam durma modu
G62 = Otomatik köse geçme
G63 = Kilavuz modu
G64 = Kesme modu
G65 = Makro çagirma
G66 = Modal makro çagirma
G67 = Modal makro çagirma iptali
G68 = Koordinat sistemi döndürme
G69 = Koordinat sistemi döndürme iptali
G73 = Gagalama ile delik delme çevrimi
G74 = Sol kilavuz çekme çevrimi
G76 = Finis delik isleme
G80 = Çevrim iptali / Dis operasyon fonksiyonu
G81 = Delik delme çevrimi, punta salma, dis operasyon
G82 = Delik delme çevrimi
G83 = Gagalama ile delik delme çevrimi
G84 = Kilavuz çekme çevrimi
G85 = Delik isleme çevrimi
G86 = Delik isleme çevrimi
G87 = Arka delik isleme çevrimi
G88 = Delik isleme çevrimi
G89 = Delik isleme çevrimi
G90 = Mutlak komut
G91 = Artimsal komut
G92 = Is parçasi koordinat sistemi tesbiti veya azami
G94 = Dakikadaki ilerleme
G95 = Devir basina ilerleme
G96 = Sabit yüzey hizi kontrolu
G97 = Sabit yüzey hizi kontrolu iptali, sabit devir
G98 = Çevrimlerde baslangiç noktasina çikma
G99 = Çevrimlerde emniyet noktasina çikma
G107 = Silidirik interpolasyon
G150 = Normal dogrultu kontrolu iptal modu
G151 = Normal dogrultu kontrolu sol kisim açik
G152 = Normal dogrultu kontrolu sag kisim açik
pinacoloda
eyvallah tam benim gibi bi acemiye göre :D
hendeseci
G08 P1
G08 P0
ne demek? Bilen paylaşırsa memnun olurum.
fanuc dik işlem için g12 komutunu nedır bılen veya kullanan arkadaslar yardımınızı beklıyorum SAYGILAR
orkunatess
G8 P1 Mitsubishide high speed komutu olması lazım
orkunatess
evet G8 P1 mitsubishide high speed açma kodudur , benim tezgahın panelide mitsb.. bende kullanıyorum
