Basit freze işlemi
Başlatan heidenhain, Kasım 04, 2012, 11:21:25 ÖS
heidenhain
Parmak freze ile baklava dilimi gibi dört köşe frezeleyelim
0 BEGIN PGM TURKEYCNC MM
1 BLK FORM 0.1 Z X+0 Y+0 Z-20
2 BLK FORM 0.2 X+100 Y+100 Z+0 ........................... KATI MODEL TANIMLAMA
3 TOOL DEF 1 L+0 R+8 .............................................. TAKIM TANIMLAMA
4 TOOL CALL 1 Z S4000 ............................................ TAKIM ÇAĞIRMA
5 L Z+100 R0 F MAX .................................................. GÜVENCELİ YÜKSEKLİK
6 L X-30 Y+50 R0 F MAX ........................................... PARÇA DIŞINDA KONUMLAMA (TAKIM TELAFİSİ OLMADAN)
7 L Z-5 R0 F MAX M3 ................................................. FREZELEME DERİNLİĞİNE İNME
8 L X+0 Y+50 RL F400 .............................................. KENAR BAŞLANGIÇ NOKTASINA YAKLAŞMA (RL/RR) (TAKIM TELAFİSİ RL=G41 EŞANLAMLI)
9 L X+50 Y+100 ....................................................... DİĞER KÖŞE KOORDİNATLARINA GİDİŞ
10 L X+100 Y+50......................................................
11 L X+50 Y+0..........................................................
12 L X+0 Y+50 RL ..................................................... SON KÖŞE NOKTASI
13 L X-30 R0 F MAX M5 .............................................. TAKIM TELAFİSİ KALDIRARAK PARÇADAN UZAKLAŞMA (R0=G40 EŞANLAMLI)
14 L Z+100 R0 F MAX M2 ........................................... YUKARI KALKMA VE PROGRAM SONLANDIRMA
15 END PGM TURKEYCNC MM
heidenhain
Dört köşe parçada köşe kıralım ve radius yapalım.
Yukarda örnek verdiğimiz parçamızda bir köşesine radius, diğerine de pah yapalım.
7 L Z-5 R0 F MAX M3  ............................................... FREZELEME DERİNLİĞİNE İNME
8 L X+0 Y+50 RL F200 .............................................. KENAR BAŞLANGIÇ NOKTASINA YAKLAŞMA (RL/RR) (TAKIM TELAFİSİ RL=G41 EŞANLAMLI)
9 L X+50 Y+100 ........................................................ 2. KÖŞE KOORDİNATI
10 RND R10 .............................................................. SON VERİLEN KOORDİNATTA (2. KÖŞEDE) RADİUS OLUŞTUR R10
11 L X+100 Y+50 ..................................................... 3. KÖŞE KOORDİNATI
12 L X+50 Y+0.......................................................... 4. KÖŞE KOORDİNATI
13 CHF 5................................................................... SON VERİLEN KOKTADA HER İKİ KENARA 5 ER MM PAH OLUŞTUR (AÇISI NE OLURSA OLSUN)
14 L X+0 Y+50 ......................................................... İLK KÖŞEYE GERİ DÖN
15 L X-30 R0 M5 ...................................................... TAKIM TELAFİSİ KALDIRARAK PARÇADAN UZAKLAŞMA (R0=G40 EŞANLAMLI)
16 L Z+100 R0 F MAX M2 ......................................... YUKARI KALKMA VE PROGRAM SONLANDIRMA
17 END PGM TURKEYCNC MM
heidenhain
Basit bir örnekle yine kenar dolanma ve köşeleri kırma ve radiuslama yapalım
3 TOOL CALL 7 Z S2500
4 L Z+100 R0 F9999
5 L X-20 Y+40
6 L Z+2 M3
7 L Z-5 F1000
8 APPR LCT X+5 Y+40 R3 RL F300
9 L Y+90
10 CHF 20
11 L X+60
12 L X+90 Y+80
13 L Y+40
14 CHF 10
15 L X+60 Y+10
16 L X+5
17 RND R10
18 L Y+40
19 DEP LCT X-20 Y+40 R3
20 L Z+100 R0 F MAX M2
21 END PGM TURKEYCNC MM
Engin Erken
Paylaşımlar için teşekkürler. Ben normal, üniversal freze tezgahlarını pek kullanamıyorum açıkçası.. Torna'ya daha yatkın gibiyim. CNC freze nasıl acaba zorluğu ve kodlama bakımından cnc torna ile kıyaslarsak ? :)
heidenhain
Alıntı yapılan: Engin Erken - Kasım 04, 2012, 11:58:26 ÖS
İşin mantığını bildikten sonra tüm CNC üniteleri ve sistemler birbirine çok yakın.
Frezelerin normal tornadan farkı 1 ekseninin fazla olması. (en azından)
Kodlama olarak ISO formatı G ve M kodları tornada da frezede de aynı.
Programlama mantığı yukarda da belirttiğim gibi her ünitede aynı olmasına rağmen programlama şekilleri farklı.
Diyalog sistemiyle programlama en basit ve rahat olanı. Hata ihtimali daha az. Ezber gerekmez. Sadece yapılacak işlem için hangi kategorin mevcut, farklılıkların ne olduğu bilinirse yeterli olur.
Diyalog sisteminde de tek lider Heidenhain olduğu inkar edilemez.  :D
Engin Erken
okulumuzda cnc tezgahı olarak sadece torna var. onuda 1 ay sonra felan kullanmaya başlarız sanırım şuan G ve M kodlarını öğrenmeye başladık bir tanede torna parçası (kademeli tornalama) programladık. Şuan için pek bi zorluğu yok ama ilerde ne olur bilemem :) Bu seneyi soru sora sora geçireceğiz, seneye staj yerlerinde öğreniriz neyin ne olduğunu:) Şuan üniversal freze tezgahlarında kendimi geliştirmem gerekiyor. onuda sağolsun sınıfta sevdiğim arkadaşlarım var onlardan yardım alarak öğreneceğim. Sizleride abim gibi görüyorum. :) Sorularıma cevap verdiğiniz için teşekkür ederim :) Birde dün özel mesaj atmıştım size gelmedi mi acaba?
heidenhain
Alıntı yapılan: Engin Erken - Kasım 05, 2012, 03:17:05 ÖS
...... Birde dün özel mesaj atmıştım size gelmedi mi acaba?
Hayır mesaj almadım.
L X100
RND R10 dedigimizde X100 git buraya radüs 10 yap  burda x100  alt satırına mı RDN R10 yazıyoruz bugün denedim yanyana yazılmıyo....
heidenhain
#8
Alıntı yapılan: yaman - Kasım 07, 2012, 09:59:36 ÖS
L X100
evet aynen
L X 100 e git
RND 10 (gittiğin köşede verilen Radiusu yap anlamında)
CHF ve RND komutları tek başlarına verilirler. Kendilerinden önce verilen noktada köşe kırma veya yuvarlama işlemi yaparlar.
Her ikisine de verilen değerler (RND 5 veya CHF 5)  köşenin her iki uzantısında eşit şekilde oluşur.
Yani CHF ile verilen değer kırılması istenen köşenin kesişim noktasında her iki yanakta verilen değer uzantısında, RND ile verilen değer de köşedeki açılıma  verilen radius değerinde tanjensiyel kesişimle oluşur.
7 L X+0 Y+30 RL F300 M3
8 L X+40 IY+5
9 CHF 12 F250
10 L IX+5 Y+0
5 L X+10 Y+40 RL F300 M3
6 L X+40 Y+25
7 RND R5 F100
8 L X+10 Y+5
temur
bu heidenhainde program sonunda referansa git yok mu?
heidenhain
Alıntı yapılan: temur - Şubat 09, 2013, 10:50:08 ÖÖ
Referansa git derken tablanın son konumunu mu kasdediyor sunuz?
bosch16
Bildigim kadarı ile x  y  ve z eksenlerinde referans yok.İstedigin noktaya deger verilerek gidilebilir.Fakat B  ve C eksenlerini kastediyorsan eger tezgahın kendi sıfırı olarak algıladıgı nokta var.
C 0  B 0 fMAX M91 komutu tezgahın kendi sıfırına gitmesini saglıyor.
rıdvan_41
sanırım arkadaşın bahsettiği fanuc tezgahında g91g28x0y0z0b0 aynı bunun gibi heidenhain var mı demek istiyor benım anladığım bu kolay gelsin..
adilbir
Arkadaşlar heidenhain tezgahı sadece ilk açıldığında referans ister bir kere referans aldıktan sonra referans gerektirmez G28 G30 GİBİ REFERANS noktası  yoktur.BAZI TEZGAGLARDA İSE TAKIM DEĞİŞTİRME ESNASINDA  REFERANS NOKTASI BULUNUR YİNE G28 G30 YAZMADAN TAKIM DEĞİŞTİR DEDİĞİNDE TAKIM DEĞİŞTİRME REFERANSINA GİDER
