İŞLEME MERKEZINDE BARA AYARLAMAK KOMPROTOR YARDIMIYLA YAPILIYOR...
SIRAYLA ANLATALIM..
KOMPROTORU TABLAYA VEYA SABIT BIYERE KOYARIZ..(ONCE KOYUCAĞİMİZ YERI TEMIZLERIZ)
BARAMIZIN ORTA CAPINI (MANUEL)EL CARKI ILE KOMPROTORE DEĞDIRIRZ..
KOPROTORUN İBRESINI SIFIRA GETIRIRZ...
BARAMIZI EL ILE CEVIRIP SALGI VARMI DIYE BAKARIZ..
EKRANDAKI Y DEĞERINI YAZARIZ..(KOLAY OLMASI ICIN Y DEĞERINI YUVARLIYA BILIRZ.YANI KOLAY BOLUNE BILIR SAYIYA ALABILIRZ...)
BARAMIZI HANGI ÇAPA AYARLIYCAKSAK ONA GORE HESAP LARIZ..
ORNEĞİN CAPIMIZI 280 AYARLIYCAZ..
BARAMIZIN ORTE ÇAPIDA 94 OLSUN..
EKRANDAKI Y DEĞERIMIZDE (KOMPROTÖRÜ DEĞDIRIP SIFIRDADIĞIMIZ DEĞER..)82.600 OLSUN.
ŞİMDİ FORMUL İLE HESAPLIYALIM..
280-94=186\2=93
82.600+93=175.6..
Y EKSENINI 175.6 DEĞERINE CIKARIYORZ..
VE ELMAS UCLARINI (KARTÜJ LERI) GETIRP KOPROTÖRE KADAR ACIYORZ..
YANLIZ ELMASIN DEĞDIĞI EN UC NOKTADA AYARI YAPIYORZ..YANI X TEDE ONNATIP Z TEDE OYNATIP EN UC NOKTAYI BULMALIYIZ..
KOMPROTORDE SIFIR DEĞERINE GETIRIP FNIŞ ELMASINI SIFIRLARIZ..
DİGER ELMASIMIZI 2MM DÜŞÜK SIFIRLAYA BILIRZ(İSTEGE BAĞLI FNIŞ ELMASI ZORLANMAMMASI ICIN.TALAŞI EŞİT PAYLAŞŞINLAR..)
YANI EKRANDAKI Y DEĞERIMIZ 175.600 İSE BUNU 173.600 YAPABILIRZ..
DÜŞÜK OLAN KARTÜJ FNIŞ KARTÜJÜNDEN 0.2 GBİ ONDE OLMALI TABI BU KARSIDAN KARSIYA GECICEK OLAN DELIKLER ICIN..
FATURALI DELIKLERDE ELMAS FATIRAS BIRAKIR DELIK DIBINDE..
İŞİMİZ BITINCE TEKRAR KONTROL EDIP SKARIZ..
NOT:
EĞER BARA GIRICEK OLAN YER HASSAS İSE VA TEK PARCAYSA FRE DE VERMEK ISTEMIYOSANIZ ŞU YONTEMI DENEYIN..
FNIŞ BARAYI 0.1 GBI KUCUK AYARLAYIN..VEYA TAM AYARLADINIZ BARANIZ GIRDI OLCU KUCUK CIKRI..
KUCUK OLCU TELAFI EDILE BILIR AMA BUYUK CIKARSA İŞTE ONA YAZIK..
KUCUK CIKTIYSA CAPIMIZ TEKRAR KOMPROTORE ALMAK UZUN ZAMAN..
NEKADAR KUCUK CIKTI ORNEĞİN0.2 DEĞİLMİ..
FNİŞ ELMASINIZI SOKUP SAĞ KENARINA (VEYA NERDEN BUYUYOSA ORAYA )0.1 LIK KAĞİT KOYUN..NORMAL KAĞIT OLABILIR DEFTER KAĞIDI BEN SIGARA JİLETINI KOYUYORM ŞU İÇİNDE PARLAK OLANDAN...
BUSEFER OLCUNUZ TAM CIKAR HEM ZAMAN KAZANIRSINIZ KOMPROTORE ALMAZSINIZ BARANIZI,HEMDE PARCA FRE VERMIS OLMAZSINIZ...
KOLAY GELSIN....
taskaya_86 parmaklarına sağlık güzel anlatım olmuş
teşekkürler taşkaya emeğine sağlık.
yalnız tam olarak anlamadığım bir şey var.takımın salgısına bakın demişsin .çift elmaslı kaba baradanmı bahsediyorsun.eğer böyle bir takımdan bahsediyorsan elmaslar kesinlikle eşit olmalı yoksa tırlama yapar.
elmas arkasına kağıt koymada bana pek güvenli gelmedi.
Hakan abı nerdeyse hergun bara ayarlarım..
iki elmaslı baralardan bahsettım ewt..
eğer ıkısıde eşit olursa fazla paso kaldıramazsın..
10mm pasoyu cok rahat kaldırır..
bırı onde olmalıkı elmasın pasoyu paylassınlar tek elmasa yuk bınmesın dıye dusunuyorm..
kağıt koymamda hıcbır problem cıkmıyor..
sureklı yapıyorm ve fre vermıyorm..
eğer faturalı delık baraladığım zaman senınd dedığını yapıyorm..
eşitlıyorm kı delik dıbınde fatura bırakmasın...
taskaya_86
önde olmalı derken çap olarakmı yoksa boy olarakmı demek istedin acaba?
birde çalıştıgım yerde 2 boyutlu ölçüm cihazları (mihengir) gibi dijital göstergeli takım ölçer var
özellikle kaba baraları ayarlamak cok hızlı ve pratik oluyor
zaten bir bara birde özel rayba takımlarında ihtiyaç duyuyorum
taskaya teşekkürler
yalnız bi tavsiyem olacak takım ölçüm cihazı aldırın
hem zamandan kazanın hemde olası hataları parçayı bozmadan önleyin
takım boylarınıda tezgahta ölçme derdinden kurtulun sadece takımı magazine yerleştirin ve kaldığınız yerden devam edin
kazanmış olduğunuz zaman ölçme cihazına yaplan yatırımı fazlasıyla karşılayacaktır
Harun abım ah bende cok ısterımde şuanda takım zor alıyorlar ınan..
crısıs,ufak olude olan kartüj 0.1kadar (z boyu)onde olsa demek ıstedım..
cunku 160 capındakı deliği 170 yapıcak olsak
0.1mm önde olan kartüj 165 ayarlarız ki fniş kartüjüne hepsı kalmasın..
tabı elmasınada bağlı..
iki kartüj de pasoyu paylasmıs olur..
taşkaya 86 emeğine sağlık
y değerini yazarız demişsin y değeri nereye yazıyoz
benim çalıştığım yerlerde genellikle böyle yapıyoruz
tutucumuz bt40 ise kompratörü 63 kısma değdirilir y ekseni + - oynatılır ortası bulunur kompratörü 0 a ayarlanır sonra x ekseni merkeze kaçırırız 31.5 sonra x sıfırlarız deliğn yarıçapı kaçsa ona göre kaçarız
elmas uçlarını kompratörün tam ortasına göre ayarlamayız sonra istediğimiz hassasiyette deliği işlemiş oluruz.
açmış olduğun paylaşım güzel bilmeyen bu mesleğe yeni başlayanlar için iyi olcağını düşünüyorum.
abi içinde paylaşma sevgisi isteği olan paylaşıyo helal olsun yani diyorum.emeğine sağlık
Alıntı yapılan: ercan_3589 - Eylül 03, 2008, 09:12:51 ÖS
bara ayarlarken kağıt uzerınde hesap yapıyorz ya unutmamak ıcın y eksenını kaldırdığında değer değişicek
daha sonra hesabı yapınca ıstedığımız olcuye alırz....
paylasmak guzel bısey..
öyle olsa öğretmenler bısey öğretmezdı..
formulün daha kısa yontemı:
bara mızın orta merkezını alacağimiz capa komprotoru değrırp sıfırlarız..
baramızın capı kac???orneğin 110 olsun
y değerımıze baramızın yarı capını yazarız..
yanı y55 meyzur derız...
ayarlıyacağimiz cap kac??*orneğin 160 olsun...
160/2=80
y 55 uzerıne 80 tamamlarız..
yanı değerımız y55 iken manuelle y80 cıkartırız..
boylece kağit uzerındekı hesap oyalanmasından kurtulmus olurz...
ELİNE SAĞLIK ALİ RIZA ABİ
sana sağlık kardesım ne demek
ilgin ve alakan ,için teşekürler.
arkadaslar bu kadar ugrasmaya formüle ne gerek al bir talaş ölç komparatörle ver talaşı
ne gerek var derken????
ozaman anlatta bızde bılelım olmazmı???
once saygı duyalım bırbırımıze kardes
Alıntı yapılan: iscar - Aralık 12, 2008, 03:45:17 ÖS
siz anlamadınız galiba.
taşkaya sağolasın iyi anlatmışsın taşkaya arkadaşımızın anlatthı bara kartuşlu olanlar eğer orjinal baraysa üzerinde cetvel gibi mm işareti vardır öyle sizin dedihiniz gibi ver gitsin olurmu .
mikrobar olsa ölç ver talaşı tamam neden mikrobarlar hassastır ben binde iki talaş verilebilen hassasiyette mikrobar kullanmıştım yüzde 1 talaşmı vercen yüzde bir veriyorsun ikiye bölmene gerek yok her yer almıyor 2.5 milyar gibi bir fiyat söz konusu.
bundan daha guzel acıklanamazdı tesekkur ederım bı melek dasın olrakk basarılarının devamını dılerım.
tesekkur ederz kardesım
genelde çoğu kişi böle yapar ama zaman kaybı
bence formülle bulmak yapmak daha iyi hem zamandan hemde işin hassasiyetini tutturuyorz..
kendimizi hem formüle hemde pratike alıştırmalıyız.
önemli olan formülü vermek değil paylaşım sevgisinin olması..
Bugün İlk defa Bara imalatı yaptım çalıştığım firmada (SK 50 VT36 Modeli BARA) ve ne işe yaradığını öğrendim. iyi oldu bu konu ya. Süpersin Taşkaya
sende oylesın gürsel im ;)
Alıntı yapılan: scorpionteam - Eylül 01, 2008, 05:24:45 ÖS
bencede söylediğinde hata var eger elmasın her ikisinide aynı ayarlarsan iş alamssın
en azından aralanında 0,2 olsun
ben im basıma geldi her iki elması aynı ayrladım
1 mm alamadım acayip bir sekilde tırlama yapıyor
ali rıza beni bir arayabilirmsin ?veya telefonu ve ben arayayım.
no tel 470 34 55
''TUNA ERDEM'' İSİMLİ ARKADAŞ ESPİRİ YAPIYOR HERHALDE YOKSA ONUN DEDİĞİ YÖNTEMLE BUGÜNKÜ ŞARTLARDA İŞ KOVALAMAK VE SAĞLAM İŞ YAPMAK ÇOK ZOR ÖNCE BOZ SONRA ÖLÇ GİBİ BİŞEY YANLIŞIM VARSA DÜZELTİN SADECE KENDİ FİKRİMİ PAYLAŞTIM HERKESE KOLAY GELSİN
emeğine sağlık kardeşim
estağfurullah ne demek....
güzel anladım...
Alıntı yapılan: taşkaya - Aralık 12, 2008, 04:09:20 ÖS
taşkaya özürdilerim kardeş amacım küçümsemek yada saygısızlık yapmak deyil biraz bencil bir cevap yazmışım bilen için bara ayarlama kolay bir olay ama bilmeyen için senin anlattığın sistem tabiki mükemmel
Valla taşkaya ne güzel anlatmışsın . benım işlediğim delik çapları bayağı bi büyük oluyor.2 mm finish e bırakıyorum daha sonra baramı ayarlıyorum kaba 5 mm kadar giriyorum delik kompratörü ile kontroL edip . finish e ne kadar paso varsa .komp.. ile ayarlıyorum . uzun da oluyor. senin formul bayagı mantıklı geldi . tşk paylasımın için .
deligin buyuk olur tabı fınıse 2 mm talasmı bırakılır.bara (hele bide ufak bara ise )elmasının cigeri nekı tek taraftan 1mm alsın
astara dostum sen beni yalnış anlamışsın . yada ben anlatamadım büyük oluyor derken işlediğim Çap Lardan bahsetmek istedim.3oo ve üzeri çapları işliyorum . 2oo mm den fazla dalıyorum .1 ila 2 mm arası finishe bırakıyorum hiçte sıkıntı yaşamadım . elmasım iscar olduğu ıcın cayır cayır degıl çatır çatır kesiyor. :) o.o25 tolarence . zaten elmasların aralarında o.25 ila 0.75 fark oluyor tek taraflı talas kaldırmıyor senın anlayacağın yinede saol önerin için
BUYUK DELIKLER BIRAZ ZAHMETLI OLUYOR BENIM BARALARLA CAP 330 KADAR 380 KADAR CIKIYOR...CAP TA KALAN PASO ILE TEK KENAR DA KALAN PASOYU KARISTIRMAYALIM ARKADASLAR...1MM CAPTAN BILIYORSUNUZ 0,5 PASO ALIR ELMAS..TAM TURDA 1MM YAPAR..AZ PASO VERIRSENDE ELMASI SURTUNMEKTEN YAKMIS OLURUZ....
öncelikle anlatım güzel,
bende çok sık bara kullananlardan birisiyim benim de yaptım şöyle delik çapını 1 mm kaba işleyip ,
bara takımını deliğin içine sokup kartuş gevşek bir şekildeyken işlemiş olduğum 1 mm kaba yüzeye dokundurup kartuşu sıkıp komprötörle ölçebileceğim kadar 5-6 mm girdikten sonra ölçüp kalan talaşıda sonra verip devam ettiriyorum ,, kolay gelsin..
bizde bara kullanıyoruz ama sizin anlattığınız hesapların hiç biri yok bizde tamammen elle bizde önce kaba boşaltma için drilll kulanıyoruz bu drill boşaltma yaptıktan sonra finişte baraya ölçüsüne göre değişir ama onda dört veya yarım mill faso bırakıyor barayıda tam ölçüye yakın kumpasla ölçükten sonra tekrar faso vererek ölçüye getiriyoruz
