http://img532.imageshack.us/my.php?image=kareilemeke1.flv
bu program okumalarda paket program olarak var
bende bu programın macrosunu kendimi denemek için yaptım paylaşmak istedim
DEF WORK[1]
DIREC V
INDEX B,0
ORIGIN H1
CYLNDR 2P,[-80,-80],[80,80],-50,0
CYLNDR 2P,[-50,-50],[50,50],-10,0
END
VC101=100 (y ekseni kenar uzunluğu)
VC102=100 (x ekseni kenar uzunluğu)
VC103=2 (r yaklaşma)
VC104=-10 (z derinlik)
VC105=1500 (f ilerleme)
VC106=10 (d takım yarıçapı )
VC107=3 ( z de bir seferde gideceği mesafe)
VC108=50 ( z ekseninde f ilerlemesi)
VC109=0 (x ekseni merkezi)
VC110=0 (y ekseni merkezi)
VC111=[VC106*2]-[VC106/3]
VC112=VC107
VC112=VC112-VC107
VC115=0
IF[VC106 GE [VC101/2]]NA9999
IF[VC106 GE [VC102/2]]NA9999
T100M6
G15H1
G90G0G56H1X=VC109Y=VC110Z=[VC03+100]
G90G0X=[VC102/2]-VC106Y=[VC101/2]-VC106
VC100=[VC101/2-VC106]
VC100=[VC100-VC111]
G0Z=VC103
NA001
G01Z=VC112F=VC108
IF[VC115 EQ 0]NL001
IF[VC115 EQ 1]NL002
NL001
G01X=-[VC102/2-VC106]F=VC105
VC115=1
GOTO NL003
NL002
G01X=[VC102/2-VC106]F=VC105
VC115=0
NL003
Y=VC100
VC100=[VC100-VC111]
IF[VC100 LE [-VC101/2+VC106]]NA02
GOTO NA001
NA02
IF[VC100 EQ [-VC101/2+VC106]]NJ02
VC100=[VC100+VC111]
IF[VC115 EQ 1]NR001
IF[VC115 EQ 0]NR002
NR001
VC115=0
GOTO NR003
NR002
VC115=1
NR003
VC100=[-VC101/2]+[VC106]
GOTO NK001
NJ02
IF[VC115 EQ 1]NZ001
IF[VC115 EQ 0]NZ002
NZ001
VC115=0
GOTO NZ003
NZ002
VC115=1
NZ003
G90G0Z[VC103+100]
G90G0Z[VC112+2]
G90G01Z=VC112F=VC108
X-[VC102/2-VC106]F=VC105
Y-[VC102/2-VC106]
X[VC102/2-VC106]
Y[VC102/2-VC106]
GOTO NY003
NK001
IF[VC115 EQ 1]NY001
IF[VC115 EQ 0]NY002
NY001
Y=VC100
VC115=0
GOTO NY003
NY002
Y=VC100
VC115=1
NY003
G90G0Z[VC103+100]
G90G0Z[VC112+2]
Y-[VC102/2-VC106]
X[VC102/2-VC106]
Y[VC102/2-VC106]
VC115=0
VC100=VC100-VC111
NA03
IF[VC112 EQ VC104]NA05
G90G0Z=VC103
G90G0X=[VC102/2-VC106]Y=[VC101/2-VC106]
G00Z=VC112+3
VC112=VC112-VC107
IF[VC112 LE VC104]NA04
G01Z=VC112F=VC108
GOTO NA001
NA04
VC112=VC104
IF[VC112 LT VC104]NA05
GOTO NA001
GOTO NA05
NA9999
Takim yaricap hatasi(VC106 GE VC101&C102)....
NA05
M02
http://img532.imageshack.us/my.php?image=dikdrtgenjk0.flv
göndermiş olduğum linkte aynı programla dikdörtgen işlenmekte.
sadece vc101,vc102 değişkenlerine yapmak istediğiniz ölçüleri girdinizmi yeterli.
abi bu proğ.sen cam demı yazıyon????
Alıntı yapılan: taskaya_86 - Temmuz 30, 2008, 10:36:54 ÖS
hayır kardeş bu programları cam da yazmıyorum
bu elle tezgah üzerinde yazdığım program
okuma macro
göüntülere bakarsan tezgah görüntüleri
tam olarak nerden gıreceğimi soylersen cok sevınırm...
ve bu progları nerelerde kullana bılırm???
daha cok hangı ıslemlere kolaylık verır???
Alıntı yapılan: taskaya_86 - Temmuz 31, 2008, 06:29:26 ÖS
BUNLARI OKUMAYI ÖĞRENİYORUM/PARAMETRE bölümünde bakabilirsin bu programlaı heryerde kullanabilirsin çok uzun programları bir kaç satırda yapabilirsin
http://www.turkeycnc.com/okuma/cnc-okumayi-ogreniyorum-baslangic-t2460.15.html
Alıntı yapılan: biga - Mayıs 13, 2008, 07:58:32 ÖS
DEF WORK[1]
DIREC V
INDEX B,0
ORIGIN H1
END
VC112=VC107
VC112=VC112-VC107
VC115=0
T100M6
G15H1
VC100=[VC100-VC111]
G0Z=VC103
NA001
G01Z=VC112F=VC108
IF[VC115 EQ 0]NL001
IF[VC115 EQ 1]NL002
NL001
VC115=1
GOTO NL003
NL002
VC115=0
NL003
Y=VC100
VC100=[VC100-VC111]
GOTO NA001
NA02
VC100=[VC100+VC111]
IF[VC115 EQ 1]NR001
IF[VC115 EQ 0]NR002
NR001
VC115=0
GOTO NR003
NR002
VC115=1
NR003
GOTO NK001
NJ02
IF[VC115 EQ 1]NZ001
IF[VC115 EQ 0]NZ002
NZ001
VC115=0
GOTO NZ003
NZ002
VC115=1
NZ003
G90G0Z[VC103+100]
G90G0Z[VC112+2]
Y-[VC102/2-VC106]
X[VC102/2-VC106]
Y[VC102/2-VC106]
GOTO NY003
NK001
IF[VC115 EQ 1]NY001
IF[VC115 EQ 0]NY002
NY001
Y=VC100
VC115=0
GOTO NY003
NY002
Y=VC100
VC115=1
NY003
G90G0Z[VC103+100]
G90G0Z[VC112+2]
Y-[VC102/2-VC106]
X[VC102/2-VC106]
Y[VC102/2-VC106]
VC115=0
VC100=VC100-VC111
NA03
G90G0Z=VC103
G00Z=VC112+3
VC112=VC112-VC107
G01Z=VC112F=VC108
GOTO NA001
NA04
VC112=VC104
GOTO NA001
GOTO NA05
NA9999
NA05
M02
abi bunların hepsını aklında tutuyosn dımı?????
maşşallah......
mantık,aritmetik azda olsa geometri
bunları bildinmi herkes yapabilir
abi bu nasıl bir program böyle ya çok karşık abi bunu nerde yapıyon sen çok degişik abi ..
okumacı arkadaşlar bir macro denklemi var ama fanuc dilinde yazılmış bunu okuma dilene çevirebilecek yetenekli arkadaşlar lazım mümkünmü.? acilL
#2=1 >>>> bu fanuc okumada nasıl yazılır
z#2 >>> buda fanuc okuma?
#2=#2-1 >> fanuc okuma=?...
IF[#2GE-50]GOTO > FANUC OKUMA KARŞITI NEDİR?
YARDIMLARINIZI BEKLİYORUM TEŞEKÜRLER......
Alıntı yapılan: Rastlanti - Ocak 02, 2009, 09:47:42 ÖS
#2=1......vc101=1
z#2..........z=vc101
#2=#2-1......vc101=vc101-1
IF[#2GE-50]GOTO..........IF[#2GE-50]N0001
rastlantı kardeşim
açmış olduğun konuyu cevabıyla bereber buraya taşıdım macronun tüm varyasyonlarını
yapmış olduğum programadan alabilirsin
incele göreceksin
alıntı değildir tümüyle yerli imalat
made ın biga
baya yaralı bir konu
vc # değişkenlerine notepad ta ara değiştir seçenegiyle değiştirsek sanırım fanucda çalışacak mantıgına bakılırsa .
paylaşım için teşekkür ederim.
harun abı bu programı kısaltmak mumkun olabılırmı???
bende kendı fıkrımı soylemek ıstıyorm...
copy veya z- yonunde ofset kaydırarak tekrarlama yapsak bu program daha kısaya dusurmez mı???
cevabını beklıyorm...
http://img532.imageshack.us/my.php?image=kareilemeke1.flv (http://img532.imageshack.us/my.php?image=kareilemeke1.flv)
DEF WORK[1]
DIREC V
INDEX B,0
ORIGIN H1
END
VC112=VC107
VC112=VC112-VC107
VC115=0
T100M6
G15H1
VC100=[VC100-VC111]
G0Z=VC103
NA001
G01Z=VC112F=VC108
IF[VC115 EQ 0]NL001
IF[VC115 EQ 1]NL002
NL001
VC115=1
GOTO NL003
NL002
VC115=0
NL003
Y=VC100
VC100=[VC100-VC111]
GOTO NA001
NA02
VC100=[VC100+VC111]
IF[VC115 EQ 1]NR001
IF[VC115 EQ 0]NR002
NR001
VC115=0
GOTO NR003
NR002
VC115=1
NR003
GOTO NK001
NJ02
IF[VC115 EQ 1]NZ001
IF[VC115 EQ 0]NZ002
NZ001
VC115=0
GOTO NZ003
NZ002
VC115=1
NZ003
G90G0Z[VC103+100]
G90G0Z[VC112+2]
Y-[VC102/2-VC106]
X[VC102/2-VC106]
Y[VC102/2-VC106]
GOTO NY003
NK001
IF[VC115 EQ 1]NY001
IF[VC115 EQ 0]NY002
NY001
Y=VC100
VC115=0
GOTO NY003
NY002
Y=VC100
VC115=1
NY003
G90G0Z[VC103+100]
G90G0Z[VC112+2]
Y-[VC102/2-VC106]
X[VC102/2-VC106]
Y[VC102/2-VC106]
VC115=0
VC100=VC100-VC111
NA03
G90G0Z=VC103
G00Z=VC112+3
VC112=VC112-VC107
G01Z=VC112F=VC108
GOTO NA001
NA04
VC112=VC104
GOTO NA001
GOTO NA05
NA9999
NA05
M02
MERHABA YAZDIGIN BU PROGRAMLA ILGILI SORMAK ISTEDIKLERIM VAR MESELA RADUS NEREDEN VEREBILIRIZ BUNUN GIBI ILGILENIRSEN SEVINIRIM
